Hi i was jammin 2 days back and all of a sudden the computer says...the program is not responding.. so i had to restart.. it was a huge embarrasment.. How do i prevent this thing from happening?.. thanks all
geposted Sun 25 Jan 09 @ 5:52 pm
Vista?
geposted Sun 25 Jan 09 @ 6:10 pm
Yes Vista.
geposted Sun 25 Jan 09 @ 10:34 pm
turn off user control... its a nasty vista feature
http://www.howtogeek.com/howto/windows-vista/disable-user-account-control-uac-the-easy-way-on-windows-vista/
geposted Mon 26 Jan 09 @ 2:06 am
i disabled it a long time ago... i wonder what still causes the freeze..although it has happend just once.. and i also had the vdj just seize from working at times.. i disabled the windows defender and i have not had the tripping off issue since then. Do you think the windows defender trying to run can cause vdj to tripp off?
geposted Mon 26 Jan 09 @ 2:02 pm
Windows Defender shouldnt cause any problems, and should be left on, to protect your PC.
But Vista has some freezing issues... Its a buggy OS.
But if you have turned off User Control, and this was a rare thing that happened, you should be fine;)
geposted Mon 26 Jan 09 @ 8:45 pm
yea so i tot too about windows defender.. but the two times ma vdj tripped off i noticed windows defender had a funny mark on the icon situated in the task bar..
geposted Thu 29 Jan 09 @ 8:11 pm
