hello, i just installed the trial version. i was wondering if there is a way to have the "Virtual DJ" folder thats in My Documents be in C:\Program Files\Virtual DJ instead. if i move the folder will i have problems with the program?
geposted Mon 26 Jan 09 @ 11:47 pm
If you move the folder VDJ will stop working especially since it won't have a clue where you have moved it to and will be unable to access skins, language data, plugins and so on.
There is a way of getting around this however. You could look into using one of the available NTFS features - juction points, or symlinks. This however is a Microsoft filesystem feature, rather than a VDJ feature.
Is there any particular reason for doing this though?
geposted Tue 27 Jan 09 @ 12:00 am
thanks for the reply. i have no reason in particular, i just noticed that after the install i had a Virtual DJ folder in My Documents. to keep my system organized, i thought i should move it to its program folder.
geposted Tue 27 Jan 09 @ 12:37 pm
Another solution has been posted, but is only viewable by registered users...
geposted Tue 27 Jan 09 @ 8:35 pm
hello, how can i view the other replies?
geposted Wed 28 Jan 09 @ 11:42 pm
You will need to purchase a copy of VirtualDJ, and register the serial for it in your profile on this site.
geposted Thu 29 Jan 09 @ 7:43 am
just *bumping* this thread as it turns out I was asking the same question :-)
geposted Tue 14 Apr 09 @ 2:55 pm
The answer is above, and I posted the same suggestion in your other thread :)
geposted Tue 14 Apr 09 @ 3:33 pm
