every time I try to load in from the playlist it loads on top of the deck I'm playing off of.
Is there a way to have it load onto one specific deck all the time so I have the other for filler music?
geposted Tue 27 Jan 09 @ 4:24 pm
are you using the rmx to load? of a keyboard hotkey?
geposted Tue 27 Jan 09 @ 4:33 pm
mouse and I'm referring to the karaoke playlist
geposted Tue 03 Feb 09 @ 3:10 pm
Do you need to have the open deck selected before you attempt to load the playlist? This is just a guess since I don't use karaoke.
geposted Tue 03 Feb 09 @ 3:36 pm
does the load button not work while using karaoke, you have the option to load deck a or deck b.
geposted Tue 03 Feb 09 @ 7:40 pm
The load button works fine. The problem is it loads into what ever deck I have playing and it cuts the music right off every time. Do you know how you pick a specific deck for the karaoke to load onto the I will use the other deck for filler music. Thanx
geposted Wed 04 Feb 09 @ 6:08 am
