I know I'm starting to get annoying with all these laptop posts but I want to make sure I do my research before I spend the money on a new laptop...I checked pc magazine's website and they ranked hp as number 1 on their laptop catergory...I just priced one out and with a 32 bit OS it was almost $300 cheaper than the dell XPS i was looking at... I was sold on the dell until i heard the horror stories about 64bit windows. Anyone out their using an hp to mix video and what do you think about it? here are the specs for the one i just priced out. Thanks for the help everyone....
Operating system Genuine Windows Vista Home Premium with Service Pack 1 (32-bit)
Processor Intel(R) Core(TM)2 Duo Processor T9550 (2.66 GHz)
Display 16.0" diagonal High Definition HP BrightView Infinity Display (1366x768)
Memory 3GB DDR2 System Memory (2 Dimm)
Graphics card 512MB NVIDIA GeForce 9600M GT
Hard drive 320GB 7200RPM SATA Hard Drive with HP ProtectSmart Hard Drive Protection
Personalization Webcam + Fingerprint Reader with HP Imprint Finish (Fluid)
Keyboard HP Color Matching Keyboard
Networking Intel Next-Gen Wireless-N Mini-card
Primary DVD/CD drive LightScribe SuperMulti 8X DVD+/-RW with Double Layer Support
geposted Tue 27 Jan 09 @ 9:59 pm
i just upgraded to an hp to and i love mine. mine is a t8100 dual 2.1 with 4 gigs ram and an 8400 nvidia with 256mb dedicated ram for video and it works well for my use. i have the famous milisecond freeze on video when loading one in while one is playing but for the most part its tolerable. concidering i got my machine for $700 new $500 below the normal $1200 price. i have noticed if i do a long backspin or long back que it delays a bit on the main output but again i don't do that much being i set cue points and use shortcut keys to jump to them. yours has a better video cars so you might not even have the small glicthes i mentioned. basically spend the most you can and get the best processor, video card and ram you can.
geposted Wed 28 Jan 09 @ 7:04 am
you won't make a mistake with hp
good build and excellent service
never a need to be in a rush with these things ....foolish to put yourself in a situation ...go slow and check things out thoroughly b4 buying
geposted Wed 28 Jan 09 @ 10:02 am
that looks like a good unit with enough ram and powerful graphics card .....
somewhere here there is a thread about good graphics cards .... look yours up there .....
your posts aren't annoying ....YET
but if they get annoying , I'm coming over and sing at you ....... last time , poor guy developed a stutter .....
geposted Wed 28 Jan 09 @ 10:04 am
