Topic: virtyaldj temp. memory
whilst playing long vidoes the sound cuts off and sometimes it indicates not enough memory. what to do?
geposted Wed 28 Jan 09 @ 8:22 am
Check your system, sound like you need more RAM on it.
dont use alot of programs during video mixing... and maybe upgrade to a pro user? :)
Try these tweaks.
THE TWO TWEAKS:
1.) Virtual Memory – Changed to: System managed size (thanks dj-in-norway)
My computer > Properties > Advanced > Performance [Settings] > Advanced > Virtual Memory – Select “System managed size”
2.) Memory management – Changed to: 1
From what I understand, your virtual memory IS NOT all cleared out at shutdown (by default) – some data stays in your Virtual Memory unless you perform this tweak that clears your pagefiles and other data from your Virtual Memory at shutdown.
Start > click Run > Type “regedit” > (in the left menu expand) HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > Session Manager > Memory Management (folder) > (right side pane, double-click) Clearpagefileatshutdown. The Edit DWORD Value window will be displayed. Type 1 in the Value data field, then click OK. Exit the Registery Editor. Restart for changes to take effect.
Here is the original Post:
https://virtualdj.com/forums/101270/General_Discussion/Freezing_Video_-_Continuing_my_detective_work.?page=1
Diamond G
