HELLO FRIENDS OF DENON DJ QU WANTED TO SAY TO THEM THE PROGRAM IS BUNO, ONLY HIM(HER) FATA SOME THAT QUEÑAS SEWS THAT THEY ARE VERY IMPORTANT.
1.-THAT ADDS THE OCION OF POINTS HOT STARTS OR CUE HOT STARTS THIS OBCIN HAS THE PROGRAM PIONEER PRO SVJ AND ALSO THE COMPACTERAS DENON DN-S 5000 - 5500 - 9000 - 3700, ECT THE SUN IS ABSENT VIRTUAL DJ IN ORDER THAT IT IS THE MEJOR.Ç HOT STARTS TENEN THAT TO BE MINIMAL 4 FOR CAMCION.
2.-FATAL A BANK OF STORAGE OF MEMORIES(REPORTS) LIKE DENON, PIONEER AND PCDJ NETWORK(NET) IN ORDER THAT IT COULD GUARD IN THE MEMORY(REPORT) ALL THE HOT STARTS, CUE AND LOOP.
PCDJ NETWORK(NET) HAS ALAMCENAMIENTO's BACO WHERE HE(SHE) GUARDS THE CUE AND LOOPS AND AS ALSO THE COMPACTERA DENON DJ AND AT HOUR TENE PIONNER DJ PRO SVJ IF THEY IT ADD THIS OBCION THE PROGRAM WILL BE THE NUMBER ONE OF THE WORLD AND NADIEN PRODRA TO STOP.
3.-TAMBIEN A SINCRONISACION IS ABSENT BETWEEN(AMONG) FOUR PLATES AS TRACKTRO DJ STUIO OR THE PRO 1.02, DON NOSOTROS LIKE DJ LET'S BE ABLE DO IN BVIVO MUESTARS VERCIONES RMX COM CUATROPLATOS IT(HE,SHE) WILL BE FORMIDABLY
THANK YOU FOR PONERNE ATTENTION
I BELIEVE THAT WITH TYPICAL HESAS THE WHOLE WORLD QUERA TO HAVE
VIRTUAL DJ PRO
MAGNOMIXVJ
HOLA AMIGOS DE DENON DJ
QUISIERA DECIRLES QU EL PROGRAMA ES BUNO, SOLO LE FATA UNAS QUE QUEÑAS COSA QUE SON MUY IMPORTANTES.
1.- QUE SE AÑADA LA OCION DE PUNTOS HOT STARTS O CUE HOT STARTS ESTA OBCIN TIENE EL PROGRAMA PIONEER PRO SVJ Y TAMBIEN LAS COMPACTERAS DENON DN-S 5000 - 5500 - 9000 - 3700, ECT SOL FALTA VIRTUAL DJ PARA QUE SEA EL MEJOR.Ç
HOT STARTS TENEN QUE SER MINIMO 4 POR CAMCION.
2.- FATAL UN BANCO DE ALMACENAMIENTO DE MEMORIAS COMO DENON, PIONEER Y PCDJ RED PARA QUE SE PUEDA GUARDAR EN LA MEMORIA TODOS LOS HOT STARTS, CUE Y LOOP.
PCDJ RED TIENE UN BACO DE ALAMCENAMIENTO DONDE GUARDA LOS CUE Y LOOPS Y COMO TAMBIEN LA COMPACTERA DENON DJ Y A HORA TENE PIONNER DJ PRO SVJ SI LO AÑADEN ESA OBCION EL PROGRAMA SERA EL NUMERO UNO DEL MUNDO Y NADIEN LO PRODRA PARAR.
3.-TAMBIEN FALTA UNA SINCRONISACION ENTRE CUATRO PLATOS COMO TRACKTRO DJ STUIO O EL PRO 1.02, DON NOSOTROS COMO DJ PODAMOS HACER EN BVIVO MUESTARS VERCIONES RMX COM CUATROPLATOS SERA FORMIDABLE
GRACIAS POR PONERNE ATENCION
CREO QUE CON HESAS CARACTERISTICAS TODO EL MUNDO LO QUERA TENER
VIRTUAL DJ PRO
MAGNOMIXVJ
VIRTUAL DJ PRO
MAGNOMIXVJ
VIRTUAL DJ PRO
MAGNOMIXVJ
geposted Thu 29 Jan 09 @ 12:51 am
Please write without CAPS only to get response.
thanks
thanks
geposted Thu 29 Jan 09 @ 3:35 am
thanks
thanks
wether some one chooses to write with all caps or no caps or put a spece behind each letter should not determine if they get a responce
geposted Thu 29 Jan 09 @ 11:46 am
"Please write without CAPS"
Xeon was only pointing out forum etiquette, new users and unfortunately many regular users need to be reminded.
geposted Thu 29 Jan 09 @ 1:41 pm
he is saying in order for VDJ to be the best it needs the following:
Hot Starts - Meaning Multiple cue poits - check
Ability to save those cue points - check
Ability to control 4 turntables - check
English:
My friend, please learn how to write at least one of the two languages, as both are very poorly written, and your english is incoherent.
The features you are requesting already exist, please read the manual, OR install the SPANISH version
Espanol:
Amigo, porfavor aprende a escibir por lo menos uno de los dos idiomas, dado a que los dos estan mal escritos, y tu ingles no tiene sentido.
Las funciones de las cuales hablas ya existen, favor leer el manual o mejor, instala la version en espanol.
English:
Espanol:
geposted Thu 29 Jan 09 @ 6:18 pm
English - Yeah........what he said.
Spanish - No mas.
I'm bifocal & multi-grain, that's just how I roll.
Spanish - No mas.
geposted Thu 29 Jan 09 @ 7:54 pm
lol
geposted Thu 29 Jan 09 @ 9:51 pm
cstoll wrote :
No, but comments like that are not answers either AND maybe if the posting was in the Spanish forum and not using Google to translate the message might get a more positive response ....
** So, magnomix; please post in the Spanish forum your comments -- Thank you. **
thanks
thanks
and you post also wasnt an answer ( see that could go on for ever :) ) but i was trying to be helpful because i did not know the answer but the post before me seemed to only not be able to answer if the post was not in all caps. It just seems that this forum as far as helping a lot of new people gets a sort of elitist attitude at times
geposted Thu 29 Jan 09 @ 11:11 pm
