I am a home user and occasional party DJ, I have a Numark Total Control that I love but fustrates the crap out of me all the time. Has anyone ever had a problem where connecting the Total Control to the PC / Laptop PC sees it and yet Virtual DJ Doesn't...??? It happens to me ALL THE TIME. And it is really upsetting the crap out of me.
geposted Thu 29 Jan 09 @ 1:19 am
your firmware isnt installed or is out of date. search youtube for Numark Total control firmware and follow his directions. after i installed mine i haven't had any issues with it.
geposted Thu 29 Jan 09 @ 7:30 am
Is anyone having a problem with distortion during playback?
When I'm trying to mix and move anything (crossfader, volume, EQ's etc..) the sound begins to distort and sounds really bad.
Anyone know whats wrong?
geposted Fri 30 Jan 09 @ 1:11 pm
It should be on your performance setup.
Please set sound card latency to AUTO and un-check Safe Mode / Overclock.
geposted Sat 31 Jan 09 @ 4:37 am
does vibration affect the total control while playing or is there a problem with my laptop
geposted Sat 31 Jan 09 @ 1:57 pm
from the baseline i meant
geposted Sat 31 Jan 09 @ 2:05 pm
What issue are you experiencing , the TC would not be affected by vibration.
geposted Sat 31 Jan 09 @ 3:04 pm
ok thanks its like a skippin in the sound i am using vista tho
geposted Sat 31 Jan 09 @ 8:23 pm
If I'm correct you're using Time Coded Viny (TCV), poor quality of your time code signal makes your audio output a bit unusual. Please check if you have 100% signal all the time, thus without scratching or back spinning, just mare audio playing.
geposted Sun 01 Feb 09 @ 5:53 am
I had the same issue when I started it was latency issues for the sound card that fixed my problem. Take a look at some of the performance tips people have posted about Audio Latency ;)
geposted Sun 01 Feb 09 @ 12:45 pm
thank you it has helped alot
geposted Mon 02 Feb 09 @ 7:43 am
if i buy dj in the box would it get me on the radio pls help
geposted Thu 02 Apr 09 @ 9:42 pm
If you mean VirtualDJ Radio, no. You would need a pro license for that.
geposted Thu 02 Apr 09 @ 11:16 pm
