Hi Folks,
I'm looking at purchasing a laptop in the next few weeks, which is exciting I know!
I was wondering if anyone had any advice regarding potential damage to a laptop caused by bass vibrations (I know a lot of clubs set their bass bins next to/underneath the stage)
Can you get something in the form of a shock absorber for your laptop? like a mat to go underneath your laptop or similar?
Something like those'free float' cushions you can get for vinyl decks, but for a laptop? see; http://www.udmdjstore.co.uk/details.asp?ProductID=31115
Or does bass vibration not really effect the laptops operation? I know I'm paranoid about having my sub sitting next to my pc but I know the desk vibrates a hell of a lot and I don't know if thay would effect a laptop more if it were on the desk!
I know most good laptops come with shock detection, but I don't really want the hardrives heads parking themselves every few seconds!!
I guess I'm looking for a device that will minimise vibrations to the laptop?
Your advice would be greatly appreciated! Thanks
Gray aka DJ Auz =Þ
Gray aka DJ Auz =Þ
geposted Fri 30 Jan 09 @ 4:55 am
If you've the choice, buy it! Vibrations are never good!
geposted Fri 30 Jan 09 @ 6:20 am
I've been DJ'ing with laptops since 1999 in pubs, clubs and also mobiles with a 3k Peavey system.
I have had no ill effects with vibrations whatsoever. I tend to replace the HDD every 18 months or so anyway, but I don't think you need to worry. I have never had the HDD park thingy, but it's probably better turned off anyway.
A cheap bit of foam underneath will do the job nicely if you want to suppress some of the vibrations.
geposted Fri 30 Jan 09 @ 6:44 am
Thanks for your feedback, it's nice to hear from long term DJ's who haven't had problems with vibrations !
geposted Fri 30 Jan 09 @ 6:55 am
I used laptops for 10 years with BPM Studio, PCDJ Red, PCDJ FX and VDJ and NEVER had any problem with the laptop itself.....I did however have a problem with a external hard drive vibrating too much in a club in Salt Lake a number of years ago, we set it on a stack of bar napkins and that cleared the problem right up.
I would never use foam under a laptop due to potential cooling problem...I am going to be buying a laptop again here in the next month and I was thinking about getting a laptop cooler and mount the feet from a turntable under each corner I think that would do the trick since the feet are designed for vibration isolation...and I'll get the extra cooling.
geposted Sat 31 Jan 09 @ 5:20 am
