I have the maya 44 with 2.5.0 driver. I hear the whine/whistle thru the headphones with the needle off the vinyl and I also hear it live without headphones when the needle is playing on the vinyl. Is this normal? I'm not sure how loud the whine would be if I hooked the mixer up to the amp (lazy). I did the ASIO config and muted the input boxes like our instructions however, when I do this it also stops playing my song too. Is this all ok? Otherwise it works real sweet. BTW I didn't install anything but the driver (ie: control panel).
geposted Wed 23 Feb 05 @ 7:50 pm
You need to mute the monitor in 1 & 2 and monitor in 3 & 4. I am assuming you are hearing the actual timecode.
geposted Thu 24 Feb 05 @ 4:45 am
If I do, then I have no input to the mixer at all. Which means no output to the speakers. ??
geposted Thu 24 Feb 05 @ 5:48 am
Thanks, I know what you mean. I'll give it a try.
geposted Thu 24 Feb 05 @ 6:46 pm
FYI: Handy Question, Had this same issue once I set up my MAYA44 USB.
Thanks!
Thanks!
geposted Sat 19 Nov 05 @ 10:27 pm
