Hey guys,
I have done a bmp analysis on the folder of songs that I want to add into virtual dj.
When I right click and analyze the folder it does it fine.
However when I close the program and go back and open it again and then click on the same folder that I had analyzed all of the BPM info is gone.
How can I get the program to save the info on the id3 tag?
Thanks
Thanks
geposted Sat 31 Jan 09 @ 2:56 pm
I'm referring to the VDJ program btw.
geposted Sat 31 Jan 09 @ 2:57 pm
What version are you using?
geposted Sat 31 Jan 09 @ 2:59 pm
Using Mac verion 5.2
Do I need to save a separate library or something within VDJ?
I'm just adding songs using a folder on my hd that contains my mp3's.
geposted Sat 31 Jan 09 @ 3:02 pm
ahh.I figured it out.
Needed to change permissions
geposted Sat 31 Jan 09 @ 3:19 pm
Hi khurrama, there is no mac demo/trial. Pls register ur serial at modify ur profile and get the latest version mac V5.2.1 mac.
To be noted "Unauthorized" version will damage ur system and it is not stable.
Also it be better to post things abt MAC at the mac forum. Thanks;)
geposted Sat 31 Jan 09 @ 5:56 pm
