hey i final hook up vdj to my cdj set up. but im still have a few problems ..
my first problem is, i cant control my cross fader. "its not moveing on screen" say i slide it to all the way to chanell one i can still here a lil of chanell 2 and vis versa. i am useing my mk2 mixer i am worndering if this has some thing to do with it because that also has a cross fader.
my 2 problem. is what is the normal latensy. when i press play some times i miss my cue point be cause of teh delay with vdj. im running vdj 3.4 right now
geposted Sun 01 Feb 09 @ 11:49 am
What external mixer are you using? Pioneer, Behringer etc. If your external mixer does not have midi capabilities, you will not see the x-fader move on the screen. The x-fader will only move if you move it on your MK2. You can lock the x-fader on the MK2 to Deck A and use the external mixer to transition from either deck. But you will not see the x-fader move on the screen. You will only hear audio.
Syberman
geposted Sun 01 Feb 09 @ 2:26 pm
im useing a numark x6.. and when slideing the x fader back to chanle one i still here a lil of chanle 2
geposted Sun 01 Feb 09 @ 2:37 pm
Numark x6 is not MIDI, Syberman answers your problem already.
geposted Mon 02 Feb 09 @ 1:06 am
Hi, set the crossfader of the mk2 in the middle and adjust ur sound setting in the FAME setting(If this u still using the old v3.4).
Then u may use ur external but as already suggested, do upgrade to v5.2.1 as it have great improvement;)
geposted Mon 02 Feb 09 @ 5:16 pm
