I know Shure is a good brand, but I don't want to spend $300 for a good wireless mic setup. One mic is fine, but if theres a mic package that can handle 2 mics, thats better.. My budget is around $120, but I can go higher if the build and sound quality is there.
Thanx
Thanx
geposted Sun 01 Feb 09 @ 12:39 pm
as usual mate all depends on how much you have to spend but check out shure or saimheisser both quality mics
geposted Sun 01 Feb 09 @ 12:45 pm
Wireless mics is one area where money does make a difference. I have always used Shure wireless mics with great success....
geposted Sun 01 Feb 09 @ 1:07 pm
I have a Shure SM-58 Wireless. Works nice, sounds good. Paid a decent price for it, just under 400.00 CAD.
geposted Sun 01 Feb 09 @ 1:14 pm
Damn, so theres none thats worth it for even under the $200 range?
geposted Sun 01 Feb 09 @ 7:00 pm
This is the base, entry, model http://www.pssl.com/Shure-PG24PG58-Wireless-Handheld-Microphone-System
geposted Sun 01 Feb 09 @ 7:38 pm
I had an audio technica that was about a 100 bucks and it worked OK for a few years. Replaced it with the Shure mic at 300 and it really does make a difference. Without changing any settings the shure mic does not feedback.
geposted Sun 01 Feb 09 @ 10:28 pm
I'm using this one and it's a real good quality mic:
Sennheiser EW 135 G2
http://www.sweetwater.com/store/detail/EW135G2-B/
Low, mid and high are very good and your voice sounds great with this microphone.
geposted Mon 02 Feb 09 @ 12:47 am
geposted Mon 02 Feb 09 @ 1:01 am
Shure SM-58. Worth every penny. Don't skimp on your wireless, you may regret it.
geposted Mon 02 Feb 09 @ 2:31 am
i am currently using the mic tayla has given you a link to.its light but very good mic great sound
geposted Mon 02 Feb 09 @ 3:50 am
Shure ;)
geposted Mon 02 Feb 09 @ 5:00 am
Have a look there http://www.akg.com/site/products/powerslave,id,914,pid,914,nodeid,2,_language,EN.html
geposted Mon 02 Feb 09 @ 5:38 am
