When I double click on a song and load it into one deck virtual dj the version with herc. would analyse (turn from dark blue to light blue) the whole song as soon as I loaded it. Now it will only analyse when I play the song and only slightly faster then the song is playing. How can I get it back to normal I have an important event soon and I would like to buy the full version if the one I have can show me that it is worth it. If not i am told pcdj is pretty good. I am familiar with vdj. and I like it but I dont trust it. I also have other problems like when I show up to an event I have to keep restarting my laptop until the thing assigns the sound card right one time only headphone will work other times the mian channel will then maybe both will. I would appreciate some help. Thank you
geposted Thu 24 Feb 05 @ 3:18 am
Hello shoreline dj
Please post your specs!
And try to change your max load setting to a time superior to the song you play.
Config-general-maxload......in vdj
Regards
Andre
Regards
Andre
geposted Thu 24 Feb 05 @ 9:10 pm
Yeah thats what it is- Just change your max load. I'm assuming you have/had it set on None.
geposted Fri 25 Feb 05 @ 7:05 am
