Can you use the "clip bank" feature to run a slide show?
or
Is this for short video clips
I tried loading .jpg's into the clip bank but they appear blank with only the blue outline
What am I doing wrong
or
geposted Sun 01 Feb 09 @ 4:42 pm
Yes clip bank uses video clips. Slideshow uses pictures (ie: jpg).
Try using the slideshow feature for your pictures. You can adjust how fast the pictures change, etc.
geposted Sun 01 Feb 09 @ 4:46 pm
kosmo you can run a video in clip bank for as long as you like, how much it takes up on your cpu depends on what your using...
geposted Sun 01 Feb 09 @ 4:59 pm
gotcha, i had not seen slide show
I will try using that
thanks
thanks
geposted Sun 01 Feb 09 @ 7:31 pm
