Got copy of virtual DJ version 5 DJC with my hercules RMX. After reading the PDF manual I've noticed that there are a lot of functions that I'm not able to access on my version at present. At the top right of the screen where the button for "config" is - mine says "more". When I click this, all it gives me the option of doing is upgrading to pro. Can you confirm if any of the settings are adjustable in my version? Also, there was a "Rip Vinyl" programe. How do I use this?
Cheers,
Mark Anthony.
Cheers,
Mark Anthony.
geposted Tue 03 Feb 09 @ 7:28 am
with the limited edition..you really can not make many changes that are available on the pro- edition..so the more/config button only gives you like 2 options check for update and 1 other i believe.
geposted Tue 03 Feb 09 @ 10:47 am
