does the hercules rmx works with virtual dj pro if it does how?
geposted Tue 03 Feb 09 @ 5:35 pm
Yes it does (from VirtualDJ 5rev7 onwards)
Once VirtualDJ is launched, you just activate it in the Remote Control tab of the config.
geposted Tue 03 Feb 09 @ 5:42 pm
just to add to jimmy, simple hook up with a usb lead...
geposted Tue 03 Feb 09 @ 8:05 pm
that's what I did ,plug in then configuration-remote control-hercules console-activate. but nothing happen so what am l doing wrong? by the way virtualdj pro rocks.
geposted Wed 04 Feb 09 @ 7:20 pm
When you plug your RMX into the USB port do the 16 backlights flash for about 6 secs
Also have you got a Green outline of the mk2 icon or is it Red
Green means the console is activated, Red means it's de-activated.
geposted Wed 04 Feb 09 @ 7:23 pm
l could'nt use the rmx with vdj so l return it and l got numark total control and works very well. GO NUMARK
geposted Fri 06 Feb 09 @ 11:15 am
well there's one happy bunny...
geposted Fri 06 Feb 09 @ 11:54 am
thanks everybody for the help no matter what virtual dj is the best software dj ever. THAT'S IT
geposted Fri 06 Feb 09 @ 6:37 pm
ditto
geposted Fri 06 Feb 09 @ 6:40 pm
