Since I've had this new Maya44 for a couple of months (warranty replacement) I have noticed that I can't change the Asio Resolution. I'm using the soundcard with the 32bit option and I can't seem to change the option to 24bit like I did with my first Maya, the option is grayed out.
Is this a problem or is it nothing to worry about or does anybody know if you can change it. I'm using the latest drivers
Has anybody else found this....
geposted Wed 04 Feb 09 @ 9:55 am
Jimmy, what are the benifits of changing this? I just checked my Maya, and it's greyed out just like yours.
Syberman
Syberman
geposted Wed 04 Feb 09 @ 9:21 pm
I don't know mate,
I was hoping someone could enlighten me, lol
geposted Wed 04 Feb 09 @ 9:33 pm
All these clever people here and nobody knows, lol
Nevermind, it's not stopping using the card or my TVC's so no worries then I guess!!!!
geposted Thu 05 Feb 09 @ 10:53 am
I quess it has to do with the driver...but i think at 32bit works fine..i also use maya with tcds with no problem.
geposted Fri 06 Feb 09 @ 8:01 am
Same situation here!
But I'm pretty sure that virtual dj will only output at 16 bit anyway (the same as what CDs are made at), so at least with 32 it's an easy conversion for the software to make.
geposted Sat 07 Feb 09 @ 7:00 am
