Im using VDJ, Maya 44, into my Nurmark mixer.
I trying to adjust the volume level of my output so I wont have to max out or push the mixer main to high. is there a way to do such if so can someone please share that info and location.
thanks alot.
thanks alot.
geposted Wed 04 Feb 09 @ 2:20 pm
The Maya 44 cards are quite low output anyway. Check your windows sound settings for the card are full up, make sure you are selecting the maya settings and not the inbuilt device.
geposted Wed 04 Feb 09 @ 2:23 pm
Are your Output sliders in the Maya44 up to max in the Maya control panel, but kradcliffe is right the Maya44 does have a quite a low output anyway :(
geposted Wed 04 Feb 09 @ 2:27 pm
oh ok..i was hoping it was the card itself really...thanks ill check the level tonight
i might need to find a better card I guess...any suggestion that wont break the bank family?
pushing the mixer i notice im loosing quality at times on certain tracks when i should have to
geposted Wed 04 Feb 09 @ 2:32 pm
Check out the M-audio Conectiv. A good soundcard, with a nice and loud output and it won't break the bank.
geposted Wed 04 Feb 09 @ 2:35 pm
Maybe the "new" maya44 is louder?
geposted Wed 04 Feb 09 @ 4:19 pm
+1
M-Audio Conectiv, I said it before and i will say it again, is loud and clear..........
geposted Wed 04 Feb 09 @ 8:31 pm
