Currently we use dac2\'s for our mixers, however on one of our systems a problem arises. We have both FX and Virtual DJ. For some reason the Dac2 only works for the FX on this system and will not work for Virtual DJ. Do you know of any reason why this might be the case?
geposted Fri 06 Feb 09 @ 11:19 am
You are running 5.2.1? PC? And you are not trying to run FX and VDJ at the same time are you?
Also, are you using any mappers (like mine)? If so, you need to download the latest version as things changed with 5.2.1 from prior versions and the mapper was updated.
geposted Fri 06 Feb 09 @ 12:56 pm
For VDJ V6, can I "de-tune" the DAC3 mapper to create a DAC2 mapper file? I've got all the DAC2 buttons functioning but can't seem to get any of the LCD display to work. I sure wish you had provided an operational mapper with V6 instead of just a dummy 'place holder' file.
Thanks -
NickyB
Thanks -
NickyB
geposted Thu 25 Jun 09 @ 11:34 am
There is a thread on General about this very thing. I have a functioning DAC-2 but wish my DMC-1 had support.
Hopefully, Pern will have time to make his mapper an XML file.
geposted Fri 26 Jun 09 @ 12:02 pm
