Can anyone help? I keep getting feedback when plug in my laptop. Ive been told its a grounding problem but not sure how to get round it? Any ideas????
geposted Fri 06 Feb 09 @ 1:27 pm
cut ground wire of eletric cable and you are done ;)
ok, don't really cut it :D cover it if you can or make cable without it.
geposted Fri 06 Feb 09 @ 1:37 pm
geposted Fri 06 Feb 09 @ 1:44 pm
All you need is one of these
geposted Fri 06 Feb 09 @ 2:31 pm
Get one of these. This way you can put it on anything.
geposted Fri 06 Feb 09 @ 10:49 pm
