So I'm using an external usb soundcard that has both left and right outputs. Right now I have one side to my headphones, and the other to the speaker system, but with this set up I only get sound on one side of my headphones and the other side of the system. How do I configure it so I get sound from both sides of my headphones and system? Thanks.
geposted Fri 06 Feb 09 @ 2:52 pm
if you are just trying to dj virtualy then i would recommend buying a cheap mixer too controll outputs, because there are many things that could be causing your issue. also what external sound card are you using? and your sound card should have a controll panel to distribute sound to certain channels. config/asio/asio config /control...
geposted Wed 11 Feb 09 @ 7:06 pm
