Hi everyone, new to Virtual DJ. No matter what skin I use, I can not fit everything onto my screen. How can I fix this? Is there a way to make everything smaller? Thank you very much. If more info is needed to answer, I will gladly give it.
geposted Sat 07 Feb 09 @ 8:54 pm
Pls register ur serial in ur profile then u can download different skins that fit ur screen from this site.;)
geposted Sun 08 Feb 09 @ 7:10 am
Also, raise the resolution on your screen, that will help everything to fit...
geposted Mon 09 Feb 09 @ 11:50 am
