Hello, I'm having some problems getting my virtual dj program working.. when I broadcast to a shoutcast server then it wont stream the music.
It connect and the shoutcast server shows it's connected and it shows what song is being streamed but I dont got any sound.
It's not the server becaus I can use other programs to stream such as Sam BC.
I have tried download "lame" but that didn't solve my problem.
So I thought "Hey! why not reinstall" but thats not easy to get the program removed 100% becaus when I remove and then install then it still have the settings in the broadcast section, which it shouldn't.
So here's my question: How can I remove Virtual DJ 100% so there is not setting or anything from Virtual DJ on my computer ???
-Jobbe
-Jobbe
geposted Sun 08 Feb 09 @ 2:54 pm
In order to remove /uninstall totally, Kindly go to your uninstall programmes list and select virtual dj, click on the uninstall botton and when prompted to indicate the mode of uninstalltion, Instead of selecting the typical uninstall radion botton, kindly select the custom uninstall botton. by so doing you would have the acess to viewing all the related files to virtual dj on your pc hence you could simply select all and uninstall.
I hope this works 4 you cos it worked 4 me too.
geposted Sun 08 Feb 09 @ 4:15 pm
how to remove virtual dj from imac
geposted Tue 10 Jan 12 @ 11:37 am
Please don't bump old topics.
This topic is from 2009 and is nearly 3 years old.
Please see our FAQ page for an answer to your question: https://virtualdj.com/wiki/How%20do%20I%20delete%20or%20un-install%20VirtualDJ.html
[Old topic closed]
[Old topic closed]
geposted Tue 10 Jan 12 @ 4:59 pm
