Hi there,
I am using Virtual DJ on a Mac pro and want to record my DJ set. I have no external recordrer, can I still
do it.
Just a newbie to this..
Thanks
JC
do it.
Thanks
JC
geposted Sun 08 Feb 09 @ 3:59 pm
On Virtual DJ, click REC next to plugins depending on the skin you're using. Then click on config and pick the place you want to save it to and all that good stuff and then just click start recording when you are ready to record.
Hope this helps.
Hope this helps.
geposted Sun 08 Feb 09 @ 5:23 pm
i think you need a license version to do it
geposted Sun 08 Feb 09 @ 5:34 pm
sure thing, get a license....
if you love the software, buy it! :)
geposted Mon 09 Feb 09 @ 10:18 am
