when ever i plug in my maya 44 usb sound card the turn tables in the program start to rapidly spin backwards even when i unplug everything from my sound card it still spins the virtual turn tables backwards.
geposted Mon 09 Feb 09 @ 1:39 pm
Go to config on vdj and then time code option and then advance view on the bottom you will see inverse stereo and phrase switch them around. or you could switch your cables
geposted Tue 10 Feb 09 @ 10:23 am
none of that helped and it does it even if nothing is plugged into maya 44usb
geposted Tue 10 Feb 09 @ 2:00 pm
nevermind i cant belive i didnt think of this before im so stupid.......the gain was up to high in my noisemap i didnt notice it because i was getting 100% sound quality so i didnt bother to look at it. the program was picking up electric vibration from the maya 44 usb because the gain was to high. much like if you have sound sensitive lighting and you turn the sensitivity up too high and put them really close to your speakers...i m sorry for the trouble guys.
geposted Wed 11 Feb 09 @ 3:13 pm
