I would ask you something about Virtual dj ? What could improve a software. The software is fantastic, but missing something. I have been dj for so many years, so I found one thing mising : master peak monitor for main output from sound card wich should be placed on the main skin; example if you\\\'re using midi controler there is no master peak on midi controler is it ? So main output cannot be controled, so in this case you get sometimes distorsion from main output wich could blow speakers to .So if this could be made on the software, then it would be perfect.I hope You will be able to make this function working . thank you ,Cheers !!!
geposted Mon 09 Feb 09 @ 8:05 pm
