How do you reset the VDJ program to recognize the current itunes library? VDJ is not updating itunes as the itunes library changes, Mackbook PRo with external HD
geposted Tue 10 Feb 09 @ 8:49 am
option 1/take look in the preference from VDJ and click the V ad automatic from iTunes.
option 2/You startup itunes and close it back, after that you startup VDJ and clik in the sidebar the map iTunes (normaly you hear the disc are read now)
option 3/Other option is to drop the XML files out of the maps from VDJ (also the external disc) and then restart VDJ.
Hold on the old XML files as backup.
sorry for my bad englisch, i hope you understand me ;-)
good luck
good luck
geposted Tue 10 Feb 09 @ 10:06 am
