Hey guys I did not see a post on problem that I'm having so that is why I need your super help.
I have virtual dj 5.2 pro and just recently bought a maya 44 sound card. I got it to work after downloading new version of driver. I also bought the virtual dj vinyls. Now when I am playing one song and trying to beat match other using time code I get breaking sound like my speakers would be blowing up(same thing in the club). I lover my input to almost zero and output to little more then a 3/4. Another problem I have is when i scratch my other song turns of for the time I scratch. Please please help???
geposted Tue 10 Feb 09 @ 10:21 am
It sounds like you have your Asio buffer set to high for your spec.
In the Maya control control on the Asio tab, try it on "fast" or "normal". The input volume you want both to be about 3/4 from the top and the output volume on full.
Also in the VirtualDJ config>Performance tab try this
Preset slider to Fastest, Latency on Auto (from the drop down)
Uncheck Safe mode and Overclock
geposted Tue 10 Feb 09 @ 11:50 am
Thx it worked great.
geposted Wed 11 Feb 09 @ 11:05 pm
