Sup Guys,
What inexpensive mixer is out there other than the Behringer ddm4000, all i need is to be able to midi the crossfader for videos.
I know the Behringer ddm4000 for some reason is not capable of doing this. I'm looking for something in the $600-$700 range.
Any advice will be appreciated.......
geposted Tue 10 Feb 09 @ 12:42 pm
I thought the DDM could?
Anyway the Korg Zero4 and Ecler Nuo4 would probably be worth a look in that price bracket.
geposted Tue 10 Feb 09 @ 2:00 pm
Go with the Nuo 4, INHO. Here's the owner's manual http://www.eclerdjdivision.com/downloads/5001410100.pdf
Buy it here: http://cgi.ebay.com/ECLER-NUO-4-0-4-CHANNEL-ANALOG-MIXER-DJ-NUO4-0-NEW_W0QQitemZ290293989913QQihZ019QQcategoryZ48459QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Syberman
geposted Tue 10 Feb 09 @ 2:11 pm
this will work as well http://www.m-audio.com/products/en_us/XSessionPro.html
geposted Tue 10 Feb 09 @ 2:28 pm
@ SBDJ
The korg looks good.......
@ Syber
That particular mixer is the new Nuo4 which doesn't have midi.
@ Reggie
Thanks but i'm looking for a 12" mixer to hook up my CDJ's and fit in my coffin (sorry i should of mention that).
@SBDJ or any Korg Zero4 user
Can the crossfader on the Korg Zero4 be midi mapped with no problems?
Thanks Again
Any other suggestions please let me know....
@ Syber
@ Reggie
Thanks Again
geposted Tue 10 Feb 09 @ 3:03 pm
Nice avatar DJPR1!
Syberman
Syberman
geposted Tue 10 Feb 09 @ 3:55 pm
it IS possible to assign the crossfader of the ddm400 to midi with the crossfader of vdj. the problem is, if you choose the midi function for the crossfader, there is no analog audio function on the crossfader.
geposted Tue 10 Feb 09 @ 4:02 pm
Yeah, and that's the problem....
geposted Tue 10 Feb 09 @ 4:40 pm
Sorry, I was going by the Ecler website that said the Nuo4 has MIDI...
http://www.eclerdjdivision.com/productCont.php?ap=2⊂=1&id=3〈=
I've not used the Zero4 in conjunction with VDJ I'm afraid so I couldn't say how well it works. I do believe the mixer can operate in MIDI and Audio modes simultaneously which is what the DDM lacks.
geposted Tue 10 Feb 09 @ 5:36 pm
Ecler Nuo 4 has midi, Nuo 4.0 not.
geposted Tue 10 Feb 09 @ 5:59 pm
Correct me if I'm wrong.....
Does the korg zero 4 has a built in soundcard as well ?
Man, this mixer looks better and better every time i look at it........
Thanks Again
Thanks Again
geposted Tue 10 Feb 09 @ 9:22 pm
The Korg has a built in soundcard. Remember the connection to the PC is via Firewire rather than USB.
Currently I am using my channel 3 fader as a seperate video crossfader and one of the knobs to scroll through video effects. The nice thing about the Korg is that you can switch the MIDI on and off for each channel on the fly. For example, If I am using VDJ audio on channels 1&2, channels 3&4 are set to MIDI control of VDJ. Say I need to play audio on channel 3 or 4 I can turn the knob and put the channel's controls back to audio/MIDI or just audio to play another audio device. I also have the Denon HS5500 hooked up via MIDI as well. The mixer is really cool, lots of really cool effects and built in sampler. The only thing I reccomend is a seperate headphone amplifier. I don't think it is loud enough for club level mixing. Other than that, I really like the mixer. I also believe the price has come down significantly over the last few months too.
Taipanic
Taipanic
geposted Wed 11 Feb 09 @ 3:13 am
Taipanic
Taipanic
I see you have channel 3 for video, so can i midi map just the crossfader to the video without the known audio problem in other mixers?
geposted Wed 11 Feb 09 @ 7:35 am
I use Korg Nano Kontrol for $60. Volume can be assigned to sliders or knobs. Loops, kills, and other buttons can be assigned as well. A decent cheap portable way if you are NOT a scratcher. Please not that this particular product is a Midi device that is only used to control, no soundcard. Plugs in via USB. Setup is easy.
geposted Sun 22 Mar 09 @ 9:52 am
