Need Help....!!!!!!------------Does anybody know if Numark Stealth Control is compatible with virtual dj......
Do i need to buy a power adapter to make it work or download a driver....
geposted Tue 10 Feb 09 @ 4:37 pm
The Stealth controller is supported on VDJ.......BUT you will require the XML mapper which is available in the downloads section.
However i beleive you with need VDJ Pro for this to work - (a Numark Rep or VDJ Rep may correct on that).
djtouchdan.....
djtouchdan.....
geposted Tue 10 Feb 09 @ 7:05 pm
You would require the pro version of Cue or Virtual DJ.
geposted Wed 11 Feb 09 @ 5:52 am
