Hi all,
I'm trying to reprogram the numeric buttons on my Hercules RMX to do 2/4/8/16 beat auto loops. These aren't options in the drop downs in the RMX skin, so think I'll need to set them by treating the RMX as a generic midi controller and editing the assignment file.
Does anyone have a midi assignment file for the RMX to get me started? Thanks a lot!
Russell
Russell
geposted Wed 11 Feb 09 @ 6:48 am
have you checked out the plug in section? plus have a look in skins at the new rmx skin made by touchdan, great work by the guy.
geposted Wed 11 Feb 09 @ 7:04 am
Thanks. Looks like some of that might help, but can't access without committing buying the a Pro version (currently using the 21 day Pro trial that came with the RMX). Hesitant to pay for a license without knowing if this will solve the problem - and still figuring out whether to go with the VCI-300/Itch.
geposted Wed 11 Feb 09 @ 10:57 am
@tayla: which skin do you refer to? i can't see a skin by djtouchdan for the rmx, only the rmx skin by clavel, which allows you to assign effects to the 6+6 buttons, but not to set fixed loops to them...?
geposted Thu 12 Feb 09 @ 12:58 pm
@blueski
I am currently trying to do exactly the same thing and I have the Pro version.
I am yet to find a fix.
See my thread here.
https://virtualdj.com/forums/104623/Hardware_Technical_Support/Hercules_DJ_Steel_functions__VDJ_5_2_1_pro.html
Matt.
See my thread here.
Matt.
geposted Thu 12 Feb 09 @ 5:41 pm
@richphillips its still in development, dan is doing a great job, check it out, it's nearing it's final draft so if you want any personal features added now is your chance for dan to consider them...
https://virtualdj.com/forums/104418/Virtual_DJ_Skins/Hercules_RMX_-_Video_Skin_-_Screenshots.html?page=1
i started the link at page one of three for you, best to read all of the pages so you can see how quickly the work has progressed
@tayla
I believe what all of us in this thread is after is the ability to change the 6+6 buttons to loops, not effects.
The page you keep linking people to is only a skin, and a video one at that.
As Dan said to me in my thread, it will not have the ability to change the effects buttons to loops, as it is a skin file, not a midi config file.
The midi config file for the RMX/Steel is what we want, and be buggered if I can find it.
If I have made a mistake in what I have said I humbly apologize.
Matt.
Matt.
geposted Thu 12 Feb 09 @ 7:08 pm
sorry but you did say which skin...
geposted Thu 12 Feb 09 @ 7:32 pm
I think what you are asking is similar to this:
Although not an idela solution it may help some of you out until native support from VDJ is released in the next update.
djtouchdan.......
djtouchdan.......
geposted Thu 12 Feb 09 @ 7:38 pm
