I've been using my Numark Total Control with Cue LE for my video show I do every Saturday Night.
The Total Control is broken so today I bought Numark's Stealth only to find out that Cue/Virtual DJ is NOT supported.
Is this true? Is there anyway I can get Cue and VDJ to work together? If I don't make something happen....I'm bigtime screwed.
geposted Wed 11 Feb 09 @ 7:41 pm
isnt it just a midi controller.... you would need to use general midi to map it .... but it also MAY need proffessional version
geposted Wed 11 Feb 09 @ 7:56 pm
Don't panic, It will work with VirtualDJ/Cue.
But you will have to use it with the General midi option (Remote control tab) and map it yourself. If you do none of the back lighting will work though, thats the only downside.
Hopefully in the next update, it will be fully supprted.
*edit*
sirkit beat me too it, lol
geposted Wed 11 Feb 09 @ 7:59 pm
You will not be able to use it with your Limited Edition version. Your LE version will only launch with the TotalControl connected.
You will need VirtualDJ Pro and you will then be able to use this MIDI file to configure the Stealth.
https://virtualdj.com/addons/6759/Numark_Stealth_Control_MIDI_Mapper.html
geposted Wed 11 Feb 09 @ 8:44 pm
This really sucks. I've got a gig on Saturday, a broken Total Control, absolutly no money to buy VDJ Pro, and Cue won't even open.
geposted Wed 11 Feb 09 @ 8:48 pm
i know this isnt the right answer but learn the basics of mixmieser or traktor which came with you controller
geposted Wed 11 Feb 09 @ 9:27 pm
how far are you from riverside ca?
geposted Wed 11 Feb 09 @ 9:39 pm
yeah if you are near cincinnati ohio you can have mine
geposted Wed 11 Feb 09 @ 9:57 pm
That's very nice of you guys but I'm in Seattle, WA.
Traktor isn't an option because neither of the programs that came with the controller support video and my gig is 100% video.
We do an art and fashion show and that stuff goes on the projectors and I play music along with it. Plus, Traktor sucks and nothing will be better than Cue.
Cue depends on the presense of a controller for the damn thing to open....so somehow I need to get an updated version of Cue but I had already downloaded the latest version of the software. Dammit!!
geposted Wed 11 Feb 09 @ 10:17 pm
have you downloaded the trail version?
geposted Wed 11 Feb 09 @ 10:29 pm
can you just use the laptop?
geposted Thu 12 Feb 09 @ 9:33 am
Using the laptop is not an option.
I need that mapping file asap or I'm seriously fucked.
geposted Thu 12 Feb 09 @ 11:25 am
i think you can scratch with a web cam?
geposted Thu 12 Feb 09 @ 9:37 pm
