Hi guys,
Im trying to make some loops to use in the vdj sampler but i cant sync them.
My loops are beats well cut in 4 and 8 bars, and i get only the jingle option and not the sync one like the "this this" loop.
Any solution?
Thanks.
Any solution?
Thanks.
geposted Wed 11 Feb 09 @ 8:10 pm
Just solved the issue finally. I was going nuts.
For those who are trying to do this here it goes:
1st: Cut your sample really good to make a perfect loop.
2nd: You have to copy five more copies of that loop to make it big like 20 seconds or more, and export them to wave or mp3 (i use adobe audition)
3rd: Put it in one of the decks and make a 8 beats or 4 beats perfect smart loop, then in the sampler you record it in loop and thats all.
If you cut the loops well, there will be no problem ;)
note: Try to make the bpm of the loops near to the bpm´s of your music..it will sound better because VDJ will not have too much work.
Hope it helped.
Cheers!
Hope it helped.
Cheers!
geposted Wed 11 Feb 09 @ 8:40 pm
