Hi,
I own the CUE version 5.0 VDJ and I am almost sold on getting the VCI-100. However, according to other posts setting up the VCI MIDI is as simple as choosing the controller in the VDJ setting since it is now natively supported. I do not see that option. There are a bunch of others, BCDxxx, Numark, Hercules and etc. Am I missing something ? Other than brain cells. I also own the Audio8, works good and plan to stick with that if its not a problem.
How do I get VDJ to see the VCI-100 if t is not listed as an option ?
geposted Thu 12 Feb 09 @ 8:28 pm
Update to 5.2.1 it is supported on this version.
geposted Sat 14 Feb 09 @ 3:13 pm
Thanks
geposted Mon 16 Feb 09 @ 8:15 am
