When the corssfader is in the middle and both tracks are playingc(or only one track, doesn't matter) the volum level is not the same when I move the crossfader to the side. When the crossfaser is at the side the music plays little bit louder. Is there any way to fix this? Thnx.
geposted Fri 13 Feb 09 @ 6:22 am
This è why you have crossfader_behaviour enabled.
You need to check the value of this shortcut and putting it to "1"
geposted Fri 13 Feb 09 @ 6:27 am
Sry, could you be more specific.
I didn't find this crossfader_behaviour anywhere. Where exactly do I have to change it?
geposted Fri 13 Feb 09 @ 6:59 am
click config at the basic skin after on the left column at the crossfader tab put it to full..
geposted Fri 13 Feb 09 @ 9:22 am
