Dude, I just have to say that the automix on "smartA" mode saved my ass tonight. I was sort of sick, and out of sorts, so I programmed a huge waitlist, and the automix mixed like a champ.
I haven't used that feature in like 2 years... all i have to say is Nice Job!
geposted Sat 14 Feb 09 @ 1:06 am
People usually mock the auto mix mode, but its handy also for toilet breaks, or when ya need to go the bar...
geposted Sat 14 Feb 09 @ 10:15 am
I've not used it before, but last night I cued up about 20 tracks of similar BPM and it seamlessly blended them together and the beats matched. Very impressed!
geposted Sat 14 Feb 09 @ 11:32 am
its an awesoe feature for stuff like that yes my only prob with it if that if its not the same bpm it will cut the hell out of it, something awesome to do would be if the songs would slow down or go up in the bpm automatically instead of cutting them....
say if you have a 90 bpm track n go up to 112 just like if you have a 125 bpm changes easily to 128
i dunno if this made sense
geposted Sat 14 Feb 09 @ 11:43 am
I'm having trouble finding AUTOMIX - which skin is it on??
Would be really useful for me - thanks
geposted Fri 20 Feb 09 @ 12:04 pm
Be careful using the Automix "Smart" mode there is a known bug.
https://virtualdj.com/forums/103856/PC_Version_Technical_Support/VDJ_DROPS_THE_VOLUME.html
geposted Fri 20 Feb 09 @ 1:38 pm
Thank you - I'm trying to use Virtual DJ between my band's live sets - I have the latest software - but I can't get the automix to work - we used to click automix on a previous version, rack up a load of tracks, and leave it play while we had our break!
This you tube tutorial is the version we used to have, http://www.expertvillage.com/video/38907_virtual-dj-automix.htm
now we've upgraded we seem to have lost the "automix" button???
This is how my current "skin" looks - http://www.expertvillage.com/video/38891_virtual-dj-about.htm
Agghhh!
Agghhh!
geposted Fri 20 Feb 09 @ 2:48 pm
I use it when the wedding party is eating!
geposted Fri 20 Feb 09 @ 10:06 pm
any chance you could tell me where to find automix & how to use it - it doesn't appear on my "skin" - HELP PLEASE!
Thanks guys & gals
Thanks guys & gals
geposted Sat 21 Feb 09 @ 6:16 am
Thanks guys & gals
Thanks guys & gals
OK
Bottom right, see "playlist" click on that and drag it across (with button still pressed)Then lock the panel with the little padlock at the bottom of the panel.
You will see a grey circle, thats the automix function. Then the + symbol is all your options within the automix.
Fill the playlist with tracks (by dragging the files across to that panel), or load a playlist into it. Then just hit the circle thing and away you go.
There are different types of automix you can do, buts it's best if you read the manual for that, or play around with it till you find something you like.
geposted Sat 21 Feb 09 @ 6:30 am
thank you jimmy b - nice one - well explained and of course it works - appreciate it!
geposted Sat 21 Feb 09 @ 6:37 am
No worries, I forgot to add, the automix just plays of one deck ( I guess you've gathered that now, lol). Also the cue points the automix puts in are adjustable by clicking on them and moving.
geposted Sat 21 Feb 09 @ 6:46 am
