What do you think?
geposted Sat 14 Feb 09 @ 11:14 am
Soooo
The m-audi torq connective is "out" since the audio 4 dj. Same price but a lot better ;-P
But the m-audio is still better than the maya44 usb ;-P
http://www.thomann.de/gb/native_instruments_audio_4_dj.htm
geposted Sat 14 Feb 09 @ 11:19 am
Yes, the M-audio Conectiv is a much better card than the Maya. It has a loud and clear output, a friend of mine has one. I have a Maya44, but I will be getting one of those when my Maya dies. There are some users on here that use it.
A good plus to this card is that it has a bypass feature (you just need the DC adapter) That if you laptop goes down or you have to do a restart then you can run on backup vinyl or CD though the card.
geposted Sat 14 Feb 09 @ 11:34 am
For ByPass i run Y-Kabels ;-)
geposted Sat 14 Feb 09 @ 11:41 am
