got a really bad hissing noise coming from my amp....i know its not the amp b/c every time i unplug my usb sound card (maya44) from my comp the noise goes away plus i use this amp for other things as well like for my keyboards and the noise doesnt happen when its hooked up to my keyboard....the mixer im using is a nuemark dxm09 not sure if it coming from there.....was wondering if any1 has experienced this b4 because id like to make it stop
geposted Sat 14 Feb 09 @ 8:23 pm
Try unplugging your laptop, see if you still have the sound when your running on batteries. If not its a ground loop.
geposted Sat 14 Feb 09 @ 8:28 pm
Use this on the laptop or mixer, and all your problems go away.
geposted Sat 14 Feb 09 @ 10:43 pm
On my laptop and hard drive i use a 99 cent 3 to 2 outlet adaptor. Works great. Everybody i know had the same problem. HAD being the key word.
geposted Sun 15 Feb 09 @ 4:15 pm
It sounds like you have a ground loop problem. You can go to any car audio store and purchse ground loop isolators. Thats what i did and works wonders.
geposted Sun 15 Feb 09 @ 5:08 pm
I had this problem till I invested in a 3 pack of 3 to 2 plugin adapters at local electronics store. It has since went away. I not trying to be cheap but if 2 usd solves it why spend a 100 dollars on it . Hope this helps
geposted Wed 18 Feb 09 @ 8:10 pm
