HI, my problem :
I want to play one song at the speaker and second at the headphones,, i was at the other forums but they dont help me :/ maybe u can help me , plsssssssss , if u can write step by step what i have to do ....
geposted Sun 15 Feb 09 @ 2:14 pm
Hi... unfortunately, I have hte same problem, Using hte MAC Version, with a Hercules MK2 console... I cant find out what is going on,...
geposted Tue 17 Feb 09 @ 8:59 pm
If u enter ur serial at ur profile, there is a tools that can help u;)
Hope to see both of u as a registered pro user soon. Regards;)
geposted Wed 18 Feb 09 @ 10:58 am
Kaszczor: You don't mention your soundcard , so it's a bit difficult to tell you exactly what to do for that part, but one thing is certain: it needs to have multiple outputs (5.1 card for example). If this is not the case, then you won,t go very far.
As for Virtual DJ, go to the Sound Setup, and configure as follow:
- Input : None
- Output(s): Headphone
-Soundcard: YOUR SOUNDCARD's NAME HERE ( Hercules DJ Console MK2 for example)
You will then have a menu where you can choose which output to use for which porpose ( Front for Main out, Rear for headphone). This will be a bit different for the Mk2 since VDJ already has a configuration for it.
- Input : None
geposted Wed 18 Feb 09 @ 2:32 pm
I try that, but this not work :/ maybe it is a my card driver fold?? i have ASIO :/
geposted Thu 19 Feb 09 @ 3:57 pm
You need the PRO version of Virtual DJ to be able to have headphone prelisten.
It will not work in Home edition, or most cracked demo versions.
geposted Thu 19 Feb 09 @ 10:25 pm
i have the same problem..
i did use VDJ 5.2 pro version..and i cant get it..why??
My sound card is RealTek HD Audio Output 4.1
I set Master:Front Output / Headphones: Centre Output
geposted Thu 26 Feb 09 @ 6:12 am
change the headphone out put to "rear channel" and see if that helps.
geposted Thu 26 Feb 09 @ 8:08 pm
