I hate to repeat posts, but I haven't been able to locate a post that has helped me up to this point. I recently switched from CDJ's to Technic 1200's w/ the stock VV vinyl timecodes.
When mixing live, I have no problems at all with drops or my latency etc until I heavily scratch in a track.
However, when I scratch heavily - the opposite channel will tend to skip. This typically only happens when I rapidly scratch. Does anyone have any insight on what I can start doing to trouble shoot?
I've experimented alot with the performance / latency settings but nothing seems to be resolving this problem. My timecode configuration is generally set to the autoconfigure option.
My performance settings are generally set up as:
Latency: 64 - 256 been experimenting with these mainly
Sratch optimized for Quality
Simple Algorithm
Basic Interpolation
Fast Master Temp
I actually have viewed the "advanced timecode view" when scratching live and the signal in the opposite deck drops out to 0% when I scratch heavily.
I hate to sound like a newbie, b/c I've been using VV for over a year without a problem - but the switch from CDJS to vinyl is giving me a headache!
The specs on my cpu are 2.4ghz dual core intel processor, XP, 3g ram.
Thanks in advance!
Simple Algorithm
Basic Interpolation
Fast Master Temp
Thanks in advance!
geposted Tue 17 Feb 09 @ 12:53 am
Try setting your scratch quality to latency. Also: put all your quality settings as low as possible to see if that fixes something.
geposted Tue 17 Feb 09 @ 3:35 am
