I am looking to convert over to VDJ. I am wanting to use the Denon DN-HC4500 controller. Does the controller have a way to use the video crossfader on the software? Also do I need to use the timecoded cd with VDJ? I am just not sure what all the features I will get using the Denon, Denon homepage was very Vague How it will work.
geposted Tue 17 Feb 09 @ 12:32 pm
You don't need timecode with the HC4500.
You can control almost any feature of VDJ, including the video crossfader. A better solution would be to use the HC4500 with a MIDI mixer, or a Denon X-Control mixer which will allow you to use an audio crossfader synced with the VDJ video crossfader.
geposted Tue 17 Feb 09 @ 12:50 pm
The 4500 is amazing with VDJ. There is a custom mapper written by JP Boggis that allows a level of control never seen before. You can only get the mapper as a licensed user, but take it from me that is is a simply superb combination. Add the Vmix 5.4 skin and you're all set. Superb!
geposted Tue 17 Feb 09 @ 1:23 pm
If I already have a mixer can I just use a midi mixer for the video fader and not use it for the audio?
geposted Tue 17 Feb 09 @ 2:00 pm
Here's the Vmix 5.4 skin in one of the video modes. It's excellent for music and video and is fully cusomisable.
geposted Tue 17 Feb 09 @ 2:38 pm
It depends. Do you want a seperate video crossfader or do you want the two linked? If you don't want the two linked, then you can just use a button combo on the HC4500 to video crossfade and don't need to worry about the mixer.
geposted Tue 17 Feb 09 @ 5:21 pm
Thanks to all for your help!
geposted Tue 17 Feb 09 @ 5:43 pm
hey im tryin to record my audio mix im im using the dnhc4500 and a denon mixer and i record it records my cue sound also
im confused right now please help can anyone help me config so i can record my mixes help thanks
geposted Wed 18 Feb 09 @ 4:21 pm
