Hi all
This is a bit off topic i know but i was wondering if anybody has any idea if you can purchass a rmx vinyl faceplate sticker anywhere just think it would be really nice if you could change the standard look of it
geposted Tue 17 Feb 09 @ 2:09 pm
something like this
make your own design and get them made at sign makers or vehicle part shops, just an idea for you
geposted Tue 17 Feb 09 @ 5:29 pm
already got my sticker, but I´m not shure how 2 get da wheels away, any tips ???
my plan was 2 take the faceplate, put the sticker with my design on it, turn it around and cut da holes for faders and knobs...
geposted Wed 18 Feb 09 @ 5:05 am
havent a clue mate. i was just thinking the same myself how would you put your sticker under the jog wheels and crossfaders
geposted Wed 18 Feb 09 @ 10:17 am
might be best if you contact hercules on that, can only think of two ways it might release, tension screw underneath or lifting the jog wheel cap and un tightening any screws found there....
geposted Wed 18 Feb 09 @ 11:44 am
here is the answer from technical support (hercules), still can`t get the jogwheels off the rmx, mayve anyone here got some new ideas .....
Quote :
CUSTOMER SERVICE ANSWER
Reference: [xxxxxxxxx]
______________________________________________________
Dear Mr. xxxxxxxxxxxxxxxxxx,
Thank you for your request. In order to resolve the issue you have encountered with your DJ Console Rmx, please refer to our response herewith:
You lose your warranty if you open the DJ Console RMX, the jogwheels can be very easily pulled out like the knobs and faders.
We thank you for your cooperation!
geposted Thu 14 May 09 @ 2:48 am
The HDJC had C-clips on the inside, I think. All I know is it wasnt going to come off without taking it apart.
-David
-David
geposted Thu 14 May 09 @ 8:18 am
