Trying to dowload vdj using windows 5.2.1 but everytime i download i get an installion error, can anyone help
geposted Tue 17 Feb 09 @ 7:15 pm
If you are running NOD32 anti virus, open the control panel and disable amon, then you can re enable it after the install.
geposted Wed 18 Feb 09 @ 9:50 am
im running norton antivirus...when you say disable amon?? what you mean
geposted Mon 23 Feb 09 @ 1:58 pm
Just disable the antivirus, and then install..
If you are on VISTA, try install as admin (right click install file and choose install as administrator).
geposted Tue 24 Feb 09 @ 1:26 am
im using windows..i have disabled, installed, used the serial key it came with, than when i click on the icon to initiate, i get an pop up saying it will try to connect to internet and see if new version is available. Nothing happens, so when i say ok to pop up, i get a red circle x saying installion error???
geposted Fri 06 Mar 09 @ 6:43 pm
