I'm trying to install the Maya 44 usb soundcard driver off the cd it came with.. I go to the Mac osx driver folder and try to install the driver when it's done a window with this pops up and my Maya 44 is still not working with VDJ and the TCV's. This is what I get when I try to install a window pops up containing this: StuffIt (c)1997-2002 Aladdin Systems, Inc., http://www.aladdinsys.com/StuffIt/
geposted Tue 17 Feb 09 @ 10:45 pm
Stuffit is a zip client for Mac. - This suggests that the installation pack needs to be unzipped first.
Try unzipping it - either by downloading StuffIt or use the built in unzipper - (right click and open with>>>>)
I am guessing as i do not have a Maya.
geposted Tue 17 Feb 09 @ 10:51 pm
I don't get it... everything was working perfectly when I was running Tiger, now Leopard is making it impossible to use TCVs
geposted Tue 17 Feb 09 @ 11:00 pm
What built in unzipper???
geposted Tue 17 Feb 09 @ 11:01 pm
what built in unzipper???
the file is as - Maya44 ControlPanel.app.sit is that a zipped file???
geposted Tue 17 Feb 09 @ 11:02 pm
yes, download StuffIt then run it - should be fine then
geposted Tue 17 Feb 09 @ 11:14 pm
