I have a 2 GHz Intel Core 2 Duo, iMac and I'm running leopard. I want to be able to use my Maya44 with VDJ as well on this computer. Is it even possible? I'm having trouble installing the driver for the Maya44 (it just will not work) I'm getting this in a pop up window after trying to install the driver StuffIt (c)1997-2002 Aladdin Systems, Inc., http://www.aladdinsys.com/StuffIt/
geposted Tue 17 Feb 09 @ 10:58 pm
why have you started another thread on the same topic??
did what i suggested work for you or not??
geposted Thu 19 Feb 09 @ 2:15 pm
