Is using Computer hard drive or external drive best when djing
geposted Thu 19 Feb 09 @ 10:24 pm
Not that it matter that much, using external drive has a little benefit.
Reason being that your Windows and VDJ will be on one drive (read/write), and music on a 2nd drive (read/write)
This will give a slight, but hardly noticable, benefit
geposted Thu 19 Feb 09 @ 10:43 pm
If you are running a laptop and videos, you won't have any choice but to run external. I always have run external without any problems.
geposted Fri 20 Feb 09 @ 6:35 am
IMO, External is best. If your machine goes down, or you ever have to upgrade, you can just plug in the external into the new machine and you're ready to go. Plus, if you ever get a virus, I wouldn't think it would effect your external. Plus, externals are pretty cheap right now, it's kinda win-win. And, if something happens to your system and say you have to do a clean install, it could save alot of ripping time to have everything on external. There are so many reasons.
CRash
CRash
geposted Fri 20 Feb 09 @ 8:51 am
Really? I use an internal drive on my laptop for audio and video, but then my laptop has two internal drive bays. I personally prefer internals - quicker setup, less wires to connect/go faulty/get unplugged accidentally. Also means you have one less power point to find (unless using a bus powered external).
I also have an external which has a backup of my media, but is soley used as that - it's not connected during a gig.
Very true - just make sure your external drive is backed up.
Thats not true at all...
Agreed, but if you can have two internal drives you get the same flexibility.
Basically just use whatever suits you :)
geposted Fri 20 Feb 09 @ 9:14 am
[quote=CRashster]And, if something happens to your system and say you have to do a clean install, it could save alot of ripping time to have everything on external.
I'm basically a Mac guy and I appreciate you setting me straight on these points. I only use my PC for DJing and don't really worry much about viruses and such. I should, but not using them for general internet and email, I don't see the need.
CRash
geposted Fri 20 Feb 09 @ 9:39 am
I don't use any AV on my gig machine either ;)
geposted Fri 20 Feb 09 @ 12:24 pm
