Hi Everyone.
Can anybody tell me where I might find some software to create Karaoke Flyers & Posters etc, hopefully with some templates and stuff so i can print something rather quckly if needed too.
Many thanks
Many thanks
geposted Fri 20 Feb 09 @ 6:01 am
Your best bet is to use some graphic software. I've used Photoshop & Corel Draw over the years to create flyers and posters.
I have even used MS Publisher - but i wouldn't advice this unless you are very confident with it.
For templates and design ideas just search the internet - you'll find something there.
geposted Fri 20 Feb 09 @ 6:27 am
good suggestions from dan, i flip between photo shop and publisher, recently came across this http://www.logomaker.com/ haven't got round to trying it yet but it's free, give it a try...
if your really stuck pm me and i see what i can come up with for you, not normally what i do but i'll give it a go.
geposted Fri 20 Feb 09 @ 7:19 am
i am a graphic designer also.... gimp and photoshop elements are cheap and or free
a quick search will get you some 'free flyer templates'
i may add a few to my website just for fun
geposted Fri 20 Feb 09 @ 8:41 am
thank you to everyone for your suggestions. I would be so greatful if you could put together some designs for me so that i can add my own text to the flyers. I have very little knowledge of this type of work so anything with Karaoke in mind would be so great. Again many thanks
geposted Fri 20 Feb 09 @ 9:47 am
