Hi,
New to the community, 1st time poster. I've been using Virtual DJ for some time now (trial version) and am now interested in adding timecoded vinyl to my arsenal. I was wondering if this soundcard will support TCV:
http://www.m-audio.com/products/en_us/Audiophile2496.htm
It has a 9-pin cable that I can break out to devices if need be.
Also, I've read that Virtual DJ supports the use of TRAKTOR SCRATCH Timecode Vinyl and wanted to verify that this is true. Are all timecoded vinyl the same, or are there different signals for different applications - i.e. - Are TCV propietary to the respective apps they are supposed to be used with?
If (soundcard works && Tracktor Scratch TCV works) then
begin
purchase VDJ this weekend
end
Thanks for any replies,
~Chipley
begin
end
~Chipley
geposted Fri 20 Feb 09 @ 11:44 am
/me looks for an Audiophile forum
geposted Mon 23 Feb 09 @ 8:05 am
Audiophile 2496 - 4-In/4-Out Audio Card
Any soundcard with 2 stereo in and 2 stereo outputs will work.
Prefferably asio driven cards, for better performance
Traktor vinyls arent officially supported by VDJ, so I'm not sure on the performace there.. But think someone posted using them.
geposted Tue 24 Feb 09 @ 1:46 am
Hiyas,
TY for the response. So, if I understand correctly, after reading the posts and researching online, I can hook up my 1200's to the line in's of the mixer I'm currently using, route the audio out of the mixer to the audio in of my 2496 soundcard, then route the audio out of the 2496 to my amp. After that, all that's needed is to grab some Numark TCV's, configure the TCV settings and I'm good to go. It seems like I'm missing something, but from all the reading I've done, the setup seems this simple.
Is it really that simple? TCV setup needs nothing more than an ASIO-enabled soundcard with 2-in/2-out, and TCV frequencies are transferred over the analog A/O?
All the apps I've read about with the proprietary hardware are very expensive, but the same can be accomplished with what I mentioned above?
Thanks again for the response,
~Chipley
geposted Tue 24 Feb 09 @ 1:51 pm
Its very simple yes... But you got the setup a little bit wrong.
1) On your analogue turntables, you will be playing a special timecoded vinyl (that produce a data signal)
2) This datasignal (from your turntables) goes into the line IN at your soundcard, and the signal is read by your PC
3) The signal (read by your PC) will control the DJ software
4) The DJ software plays digital files (mp3s) out you your soundcards OUTPUTS
5) From the soundcard OUTS, you connect to your mixers line ins... (the audio signal from your pc/dj software)
thats the way ;)
geposted Tue 24 Feb 09 @ 2:04 pm
Gotcha, so...
1) Understood
2) Almost understood - I have 2 RCA inputs on the 2496 (1 red(a), 1 white(b)), this means that I can use a RCA Y-join cable to join the 'a' and 'b' outputs from the turntable into one input, and use that single input per turntable for the 2 soundcard inputs? Or doesn't it matter whether the TCV signal is coming in from both a and b outputs on each turntable (if that makes any sense).
3) Understood
4) Understood
5) Understood
Thanks so much for your clarification,
~Chipley
1) Understood
3) Understood
4) Understood
5) Understood
~Chipley
geposted Tue 24 Feb 09 @ 2:54 pm
Not sure I understand..
You need 2 x stereo inputs.. One for EACH turntable.. at your soundcard.
It can not be shared/joined at one input
geposted Tue 24 Feb 09 @ 4:28 pm
Understood. I guess I can just test on one turntable then, then expand if I'm likin' the time coded control.
Thanks again for all your clarifications,
~Chipley
~Chipley
geposted Wed 25 Feb 09 @ 8:12 am
