Arghhh
I am trying out different skins, Red ClubDJ Pro among others. But on that skin I can't find the config button, so I can't change the skin... Is there a short keyboard shortcut I can use? (or is the choice just hidden somewhere?).
Thanks
Rajan
Thanks
Rajan
geposted Sat 21 Feb 09 @ 2:55 am
I deleted the skin in the doc folder and renamed another skin to this one. Then I could open VDJ with a skin with config button. And then I created a config shortcut, so it won't happen again...
geposted Sat 21 Feb 09 @ 8:27 am
