I have VDJ but my sister is using Numark Cue 4.... she called me last night asking me how to fix a corrupt database, and I told her to go to the Config button and then to the tab that has the database section where you can check, fix, etc. the database, but on Numark Cue, there is nothing for this... I downloaded the user's manual but it has no troubleshooting part and I didn't see anything where you can fix the database.. do you just have to delete it and re-scan everything or is it somewhere else?
geposted Mon 23 Feb 09 @ 7:30 am
She need to upgrade her Numark Cue if she doesnt have that option ;)
geposted Tue 24 Feb 09 @ 1:36 am
Yeah, I believe you're right... I will let her know that... the only other thing I could think of her to do is delete the database and then scan all of the files again and recreate the database.
geposted Tue 24 Feb 09 @ 1:21 pm
